Really slow - router says 2.6 Mbps
ToneTone
Message 5 of 5
I have rebooted my router and checked to see that the connections are ok.  What are my next steps please?  I'm on Broadband, and normally get 60-70Mbps.
ToneTone
undefined
4 REPLIES 4
Message 1 of 5
Hi ToneTone,
I can see that this has now been logged out to Openreach for further investigation, please let us know how you get on
Message 2 of 5
Ok @ToneTone .
Thanks for confirming. I hope you get back up and running soon, but if you need help further down the line please let us know.
Good luck.
ToneTone
Message 3 of 5
I also did a connection test on the main website.  They seem to have identified  fault, and OpenReach have been informed/.  Hopefully a solution is on its way.
Message 4 of 5
Have you tried turning the router off for 30 minutes to start a new session?
Did that help?
You could try a pin reset using the hole in the back of the router. This will reset the router to factory settings, but be aware that if you have changed the network name and password, these too will reset so you will have to change again.
Did this help?
Staff are not back until Monday and you are in their queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
Anonymous User
