Cant add port forward
john9871234
Message 23 of 23
Despite already having multiple port forwards set up I am now getting an error as seen in the screenshot. The device I am attempting to port forward is the exact device I have already successfully completed port forwarding on in the past.
Any advice?
22 REPLIES 22
Message 1 of 23
Yes thanks for that it is V3 then. The bug that does affect V3 is slightly different anyway.
john9871234
Message 2 of 23
Following what you mentioned previously this appears to be version 3?
Serial Number N7183024N005899
Hardware Version FAST5364 3.00
Software Version SG4K100174
GUI Version 5.100.1
System Up Time 1d 03h46m30s
MAC Address D8:A7:56:60:1F:85
Message 3 of 23
Hi @john9871234
I did tell you that the advice you were given about port forwarding not working on their consumer routers was total garbage. Out of interest, what hardware revision does this one have?
Message 4 of 23
No Problem 🙂
john9871234
Message 5 of 23
Despite what customer support has claimed about port forwarding. It is now working with the new router.
Thanks for your assistance. I will post the old router back.
Message 6 of 23
Replacement router is on the way.
john9871234
Message 7 of 23
Michelle. I've done that for you.
Message 8 of 23
  • Name
  • Telephone number
  • Alternative contact number
john9871234
Message 9 of 23
Yes please and if it works with the new one I will return the faulty one
Message 10 of 23
Just to confirm, would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Message 11 of 23
Then you must have an old hardware revision pre v3. I think the best way forward is to get a new router sent out to you. I'll ask TalkTalk to arrange this when they are back on Monday.
john9871234
Message 12 of 23
This is all the info I've got.
Also exactly the same error.ScreenshotScreenshot
Message 13 of 23
If you login into the router & go to:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Device Info > General
In the Device info section, the hardware version is quoted there.
Now that you can't add any rules is the error message still the same?
john9871234
Message 14 of 23
I don’t know where to find that info if it helps I only signed up this year I’ve attached some pictures of it
Message 15 of 23
That is absolute rubbish. Please can you answer my questions in the previous post.
john9871234
Message 16 of 23
Speaking to customer support and they are telling me that I must be a business customer for port forwarding to work as it is something they do not support for residential customers
Message 17 of 23
No, that is the model number, the hardware revision is likely to be either 3.0 or 4.0.
john9871234
Message 18 of 23
Message 19 of 23
What hardware revision is your router? It might be linked to another port forwarding problem, but that one is a bit different.
john9871234
Message 20 of 23
I've done this a factory reset and now I can't add any ports?
What should I do now???
