Connect another router by cable
catapult5
Message 4 of 4
Hi. I’d like to run Cat6 cable from my TalkTalk router in the house to a cabin in the garden. Is the best option to attach another router to the cabin end (I have an old one) and if so, how do I set it up?
3 REPLIES 3
martswain
Message 1 of 4
Yes, you need to modify and/or check settings in both devices.
https://www.techadvisor.com/how-to/network-wifi/router-repeater-3633135/
Other guides are available, some have videos.
Message 2 of 4
Thanks. Pardon my ignorance but how do I do that? Do I need to connect each router and log onto them somehow?
martswain
Message 3 of 4
Disable DHCP on the router in the cabin.
Set it to have a fixed IP address of 192.168.1.2 (as long as no device is currently set to that)
Set the main router DHCP range as follows 192.168.1.10 to 192.168.1.255
Connect LAN to LAN (yellow sockets)
