D-Link Router (DSL-3782) - RESTART (NOT Reset!)
Vanguard_50024
Message 39 of 39
Why can't I restart my router from the Admin page?
If there is another place, please advise?
38 REPLIES 38
Message 21 of 39
I'm sorry to hear this. Have you tried factory resetting the router and then re-setting it up again? What's the intermittent issue with the bingo site please?
Message 22 of 39
@Vanguard_50024
I have re-escalated this to the support team for you, hopefully they will pick it up tomorrow.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don’t worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - TalkTalk Help & Support
Message 23 of 39
Hi All who have been helping with this, just an update to tell you that my Internet has been connected and stable all weekend however I am still experiencing disconnect faults with Betfair (Bingo) but I'll only bore you with the details if you really need to know?
The white LED on my box is barely lit and certainly nowhere near as bright as the amber LED when it flashes.
I have rechecked the router webpage and it is still showing as disconnected from the internet, is there any other information I can send that will help?
RouterRouter
I await your update.
Message 24 of 39
I can only hook up the phone line from one port so have the new one still connected unless it starts giving me grief.
Message 25 of 39
Well I don't know what to make of that, do you still have your previous router connected?
Message 26 of 39
My Internet is working fine but here's something else that doesn't quite make sense either as the router thinks I am not connected to the internet?
Should I try a hard reboot of the box?
Message 27 of 39
OK, that's a wee bit odd, unless you intentionally disabled it in the router settings. But it's working OK?
Message 28 of 39
No - the white LED has not yet lit up at all.
Message 29 of 39
Presumably it's a steady white now?
Message 30 of 39
OK - I have now connected using a network cable and have established connections on both laptops (the other wirelessly) and also hooked up Skybox as well.
I think it is a bit of a poor design though to have only one LED light on the router (even if it is supposed to be on now).
I will see how the performance fairs over the weekend.
Message 31 of 39
Staff will follow up after the weekend, @Vanguard_50024.
Message 32 of 39
Chris,
The box has arrived and after swapping the phone line over and switching on I can't see a white light only the blinking amber light which starts 1/second but then slows a bit and after about a minute, it goes out?
Have tried several times and then re-connected my current router and after start-up, normal service resumed.
I visited the website for help but it tells me absolutely nothing about rectifying this fault? I cannot run both routers at the same time.
Message 33 of 39
Hi Vanguard,
I've ordered the router, it should be with you within a couple of working days
Message 34 of 39
Hi Michelle,
Thanks for the swift response, I did see the light's go out and my box seemed to re-set so presumed you had done something. Please can you send out the replacement? I gather this will not cost me anything?
I'll compare the performance for a week or so and respond on this thread.
Message 35 of 39
Thanks for confirming. I've run a test on the line now which is clear. The 3782 is one of our older routers. Would you like us to send a replacement router for testing purposes to see how the connection compares and to rule this out?
Message 36 of 39
Thanks for both replies and the reason I want to restart is for internet connectivity issues which I have experienced on and off for the last week or so. The light's on the box are showing green but I am losing connection to a specific website that has been plaguing me for months. I was thinking it is Belfair's problem but it might be TalkTalk's? The site displays a message "Server unavailable" and I have to carry out some login sequence on my 2nd laptop to restore the game I am playing. This fault has not resulted in total loss of internet as in more recent times and I am told that Betfair are looking into it and have been for 3 or 4 months???
I sometimes get the red L.E.D. (3rd one in from the left) and sometimes I get the "OOps you're not connected" message on my screen in the form of a webpage (but not entirely sure where that is coming from).
I note the comment about the age of my router but have not had any information from TalkTalk to have this updated?
The previous router had a radio button on the admin page which when clicked re-started the device.
Message 37 of 39
Can I just confirm, are you experiencing any issues with your connection? Is this why you need to restart the router?
Message 38 of 39
This begs a few questions in response! Why do you have such an old router? Is this the first time you have noticed this? Why do you want to restart it?
Restarting means simply interrupting the connection to the internet, generally achieved by switching it off at the mains and then switching it on again around 30 minutes later. A reset is usually accomplished via pinhole/button and of course is best avoided if you have any personalised settings. Not sure I have ever encountered a restart feature from a router itself?
