Disable WI-FI Optimisation
on 11-02-2022 06:31 PM
Message 20 of 20
As others have raised previously, I am also having a problem with my router changing the 5ghz wifi channel after a period of time. It's picking a channel that is more congested rather than one that has no one else on it resulting in performance problems.
Please can 'optimisation' be turned off on my account to prevent this from happening?
Labels:
- Labels:
Other
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
19 REPLIES 19
on 22-08-2022 07:35 AM
Message 1 of 20
Hi ayman786,
I've disabled wifi optimisation again
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-08-2022 01:09 AM
Message 2 of 20
Hi @ayman786,
See my initial reply from 11-02-2022 07:26 PM, if it is only your 5GHz and not 2.4GHz that is changing then there is a possibility it is being caused by DFS. If that is the case there is nothing TalkTalk can do to stop this happening, it is a regulatory requirement that a router switches away from a 5GHz channel if it detects military / weather radar using the same (or a clashing) channel.
If you are currently always trying to set the same 5GHz channel then try using different ones, possibly some of the lower channel numbers, as they may be less likely to clash with DFS restricted channels.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 10:38 PM
Message 3 of 20
It continues to keep changing Wi-Fi channels
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 4 of 20
WI-FI optimisation*
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 5 of 20
My WI-Fi has been turned off again for the 3rd time, no factory reset or fimware update had been done it works fine for a week or so, and then reverts back to that can I please have it switched off again please.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-08-2022 11:21 AM
Message 6 of 20
Optimisation is now off.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-08-2022 08:10 AM
Message 7 of 20
I'll re-escalate this, @ayman786.
Ensure that you leave the router switched ON.
Periodically wifi optimisation will resume, due to firmware updates or if you ever do a factory reset - so switching off optimisation has to be done yet again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-08-2022 05:09 AM
Message 8 of 20
The WIFI Channel are still promptly changing could I please ask if you could re do it as it hasn’t taken affect.
thank you
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-07-2022 07:43 AM
Message 9 of 20
Hi ayman786
Has the connection been working ok since your last post?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-07-2022 10:02 AM
Message 10 of 20
Hi ayman786
The WIFI optimisation should now be off. Please let us know how the connection compares.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-07-2022 07:01 AM
Message 11 of 20
Hi ayman786
I'm just looking into this further and I will post back as soon as I receive further information.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-07-2022 03:10 AM
Message 12 of 20
Hi there for some reason my wifi channels keeps changing could I please request my wifi optimisation to be turned off once again thanks.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-03-2022 02:28 PM
Message 13 of 20
Hi ayman786
The WIFI optimisation has now been switched off.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-03-2022 02:25 PM
Message 14 of 20
Can I please have wifi optimisation turned off again please I have a new talktalk router and the same problem is recurring thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2022 11:40 AM
Message 15 of 20
optimisation is now turned off.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-02-2022 03:51 PM
Message 16 of 20
Yes I have added the correct landline number, which ends in 758
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-02-2022 07:39 AM
Message 17 of 20
Hi ayman786
Have you added the correct landline number to your Community Profile? (please do not post the number on this thread)
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-02-2022 05:08 PM
Message 18 of 20
After Talktalk have switched off WiFi Optimisation set your 5Ghz channel to 44 which is not shared with civilian radar that has priority.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 07:26 PM
Message 19 of 20
Hi @ayman786,
The staff here probably won't be around now until Monday, but they should be able to respond to this post early next week to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
If the 5GHz channel keeps changing, even after the staff here have disabled Wi-Fi optimisation, then it is possible you are being affected by Dynamic Frequency Selection (DFS). All routers that broadcast a 5GHz signals have to comply with regulations that mean they check to see if the channel they are broadcasting on clashes with military / weather radar. If your router picks up a signal from military / weather radar on a 5GHz channel that could clash with the one your router is broadcasting on then your router must change channel. This is a legal requirement, and this functionality will be build into the router firmware, it can't be disabled.
Some more info on DFS can be found here : http://www.technical-direct.com/en/operating-wi-fi-network-5ghz-band-make-sure-deploy-dfs-first/
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
