Download speed
James999
Message 9 of 9
Internet speed seems slow. When I run a test speed to router is ok (29Mbps) but speed to device is slow (8Mbps). Any ideas on what is going on?
8 REPLIES 8
Message 1 of 9
Afternoon James,
How are you getting on?
Message 2 of 9
Hi James
Please let us know how the connection/speed compares with this router.
James999
Message 3 of 9
Michelle,
Let's try a Wifi Hub and see if that cures the problem.
James
Message 4 of 9
Hi James,
I'm sorry to hear this. I've run a test on the line now which is clear. I can see that you're using one of our older routers. Would you like us to send a Wifi Hub instead to see how the connection/speed compares?
Message 5 of 9
To update your Community profile, this can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Message 6 of 9
Cannot seem to get to Community Profile.
Name is: XXXXXXXXXXXXXXXXX
Landline: XXXXXXXXXXXXXX
Message 7 of 9
Hi James999
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 8 of 9
1. Is this device connected to the router via a wired (Ethernet) or a wireless connection?
2. What make/model of router do you have (if this is a TalkTalk router, these details will be on a label on the rear or underside of it)?
3. What package are you on?
4. If you have any wired connections, are they affected in the same way as wireless ones?
