Enabling QoS (traffic management) on the Hub 2 - DG8041W
Georgesel
Message 13 of 13
Hey folks 👋🏼
I'm wondering if it's possible to enable Quality of Service (QoS) on a TalkTalk Hub 2 router, specifically the DG8041W model. I've scoured the web for instructions but haven't had any luck finding guidance.
I'm experiencing difficulties with my work laptop when on MS Teams video calls and would like to prioritize its bandwidth. However, I haven't been able to locate any mention of QoS or Traffic Management in the router's advanced settings.
Any assistance would be greatly appreciated! Thanks in advance!
12 REPLIES 12
Message 1 of 13
Hi @Georgesel
Thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Georgesel
Message 2 of 13
Thanks @Debbie-TalkTalk , I've receveid it and installed the new one 🙂
I'll keep an eye on the speed and if this helps to solve my problem. Appreciate the help from everyone, I think we can close this thread.
Message 3 of 13
Hi @Georgesel
I've ordered the replacement router for you, please allow 48hrs for this to arrive.
Georgesel
Message 4 of 13
Hi @Karl-TalkTalk I wasn't able to reach out to TalkTalk yet.
Are you able to arrange that swap for me?
Thanks!
Message 5 of 13
Hi @Georgesel
Did our teams help with swapping out the router ?
Georgesel
Message 6 of 13
Thanks so much for your time Keith, I'll get in touch with TalkTalk CS and will ask for a different router.
All the best.
Message 7 of 13
ank you for the Networks Around You screenshot. First off, in the 2.4GHz band, you cannot use channel 4 as it is an overlapping channel. You can only use channels 1, 6 or 11 in this band as they are the only non-overlapping ones. I see that you are using a Huawei router, which you would probably benefit from getting this replaced. If you want this done, please let TalkTalk know.
Message 8 of 13
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
Message 9 of 13
@KeithFrench wrote:
There are no QoS settings on this router. I think that the issue is far more likely to be caused by Wi-Fi interference anyway.
Oh, that's a shame 😕
I'd really appreciate it if you can send that to me. I'm out of ideas at this point on how to make things better.
Thanks!
Message 10 of 13
Message 11 of 13
Hi Keith, thanks for your reply.
You must be right, I don’t know the commercial name of the router but the model is right since I’ve copied it from its settings.
I can’t use a cable unfortunately, but between the laptop and the router it’s completely unobstructed.
is there a way to enable QoS? I have a lot of devices connected to it, I want to give that a try.
Message 12 of 13
The Huawei DG8041W is not the Hub2, that is a Sagemcom FAST 5464. Please recheck which one you have, as they are different.
It is not likely to be a QoS issue as such, how does the laptop connect to the router via a wired (Ethernet) or wireless connection, if you can use either, is the Ethernet one better than the wireless?
