on 29-10-2024 08:49 AM
Can anyone tell me how I can get through to someone to explain that I am paying for Fibre 65 and should get a minimum of 52Gb speed. My account says I should only get 22Gb as if I am on the lower band. I complain and they check the line and say there is a fault and open reach will be calling out to check it. But I think it is a case that they have set up my account wrongly. Charging for Fibre 65 but only giving the non-fibre speed. Anyone know how to resolve this?
Thank you
on 29-10-2024 10:59 AM
Hi @ADivers830
Thank you. Can I just check, did you migrate over from Shell? (part of the Shell migration)
on 29-10-2024 10:52 AM
I now have.
on 29-10-2024 08:51 AM
Hi @ADivers830
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
