Firmware update request for vpn issues
chrispattinson
Message 23 of 23
Hello talktalk, can I please request a router firmware update as my work vpn drops constantly on a wired connection.
 Thanks Chris.
22 REPLIES 22
Message 1 of 23
Just checking back in to confirm if everything is now working ok?
Message 2 of 23
Hi Chris
Openreach have now closed this fault as resolved. Is everything working ok now?
Message 3 of 23
No updates from Openreach as yet however we will continue to monitor.
Message 4 of 23
Hi Chris
This fault is still with the Openreach line engineer. I will continue to monitor for additional updates.
Message 5 of 23
Hi Chris
Thank you. I've ran a line test and it's detecting a potential line fault so I have passed this over to Openreach.
The engineer will investigate externally on the line and I will continue to monitor for updates.
Thanks again.
Message 6 of 23
Yes ofcourse
Message 7 of 23
Hi Chris
If wired connections are also dropping then this may be an issue with actual connection and not just wireless.
Will it be ok if I run some line tests?
Message 8 of 23
Thanks for your efforts.
Unfortunately, it still keeps dropping, and now my wifes computer in another room also hardwired keeps dropping.
Also, considering the new router has reduced range (it doesn't reach my daughters bedoroom), I think the solution will be to put the old router back in, and I will have to find a WiFi solution ...... unless you have any other suggestions.
Chris.
Message 9 of 23
Hi Chris
Is your VPN connection working ok now?
Message 10 of 23
Hi Chris
Your firmware has updated to the latest version, please can you retest?
Message 11 of 23
thanks
Message 12 of 23
I think that staff were waiting for you to confirm whether the time was OK so as not to interrupt things when you were working, or whatever, @chrispattinson.
You will need to let them know, if they ask you again. They'll be back after the weekend to respond.
Message 13 of 23
Hi, can you confirm the FW update was done.
Message 14 of 23
Do you still need assistance with this?
Thanks 🙂
Message 15 of 23
Hi Chris
When would be the best time to update your router firmware?
Message 16 of 23
Hi Chris
Yes I can push the new firmware update to your router, will it be ok to do this now?
We advise to keep the router powered up without being rebooted whilst we update the FW.
chrispattinson
Message 17 of 23
I have received my replacement router, and tested it the last 2 days.
I seem to have the same issue, though the drops while on VPN wired seem to be less frequent.
Is there any updates needed for the replacement router?
Thanks, Chris.
Message 18 of 23
Hi Chris
Message 19 of 23
Hi Chris
Message 20 of 23
Hi Debbie, yes please. Thanks.
