High Ping
AdamH1
Message 7 of 7
When playing online games I'm experiencing ping that I believe is much higher than it reasonably should be (usually 90+ on EU servers which occasionally dips to 70) and with this there also comes consistent spikes up to 200 every 5-10 minutes.
Considering I've got people close to be who get better connection to NA servers than I do to EU servers I'm wondering what the problem is as it's starting to make the games unplayable due to the disadvantage.
6 REPLIES 6
Message 1 of 7
OK, thanks for trying that. Are you experiencing any problems with your telephone service. any noise on the line?
Message 2 of 7
The ping has gone down to around 60 but I'm still getting spikes up to between 100-200
Message 3 of 7
Hi AdamH1,
Could you try Skynet_TX's suggestion, if you haven't already, and let us know how you get on
Skynet_TX
Message 4 of 7
Have you tried switching the router off for over 30 minutes, this will ensure you get a new session when you switch it back on, this can sometimes help with random latency issues.
AdamH1
Message 5 of 7
Wired connection. Playing in the last 30 minutes its been 80-100 switching rapidly and never settling at one ping value
Skynet_TX
Message 6 of 7
Hi @AdamH1,
Are you testing this with a wired or wireless connection ?
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
