How to buy a Wifi hub
Bambi56
Message 4 of 4
How can I buy a w i f i h u b ?  We have a TG-588v which is less good.
3 REPLIES 3
Message 1 of 4
Hi Paul,
There is information here about setting up 3rd party routers, hope it helps - Set up a non-TalkTalk router - TalkTalk Help & Support
Message 2 of 4
No, we are not "experiencing any problems with your current router?"
However, I have seen the additional facilities offered by the w i f i h u b such as Mu Mo and 5G and since we have an old TG588V v2 I would like to know if I can buy the better one.
I also have an Archer VR2800 but can't get it to connect as ADSL although it works as a router.  Perhaps you have a configuration sheet for other routers.
Paul
Chris-TalkTalk
Message 3 of 4
Hi Bambi56,
Are you experiencing any problems with your current router?
Anonymous User
