I've been asked to return my router or I will be charged £50??
VirtuaMcPolygon
Message 5 of 5
I've received an email requesting me to return my broadband hub with a serial number on the email.
The problem is that the serial number doesn't match my replacement hub and the faulty one that is/was broken.
I had to request a new hub as the old one died with a bad firmware update putting it into a death loop on boot and a hard reset didn't fix it.
I don't think I have my old hub now as I was told to dispose of it. Just found the card only which has the serial number on it.
I don't know what to do as I cannot return something I don't have with a different serial number requested??? I thought I would ask on here as I dread to ask this on the telephone support and be past around with confused 1st liner tech support.
Many Thanks!
Been annoying people since 1976.
4 REPLIES 4
Message 1 of 5
Hi @VirtuaMcPolygon
If you post the tracking number on this thread I will add it to your account, making you exempt from any charges for equipment.
Message 2 of 5
Staff usually just put a note on your file, but the main thing is to return something, @VirtuaMcPolygon and keep a certificate of posting so you can check the tracking number.
Sometimes Talktalk is slow to process the returns, so keep your record of it!
Message 3 of 5
I've been chatting to the support via the chat support.
I've found the old router so I can return it. But as I explained to support I do not wish to be billed for returning a router that has a different serial number than expected. I always assume the worst as most things these days are automated and if they don't match up I assume by default I will be charged regardless. Ever the pessimist me...
Message 4 of 5
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
