Internet connection dropping frequently :Warning DHCPC WAN DHCP client (1) stopped
Ld1111
Repeat Guest
Message 15 of 15
Everything was working fine, and out of the blue about 10 days ago the internet connection started dropping, and then reconnecting within a minute or so throughout the day.
This can happen randomly but often at least once an hour.
There were no changes to any cable, furniture or router or anything that would influence the connection.
When this happens the light on the router goes amber, flashing amber, then flashing amber and white and then steady white, which I understand is the normal cycle when disconnected and connecting.
I contacted TalkTalk support via chat and call, and they've not been able to detect anything wrong with the line. The router was old so they sent a new one, but we are still experiencing exactly the same issue with the new one, and they pushed firmware updates and it hasn't done anything. They still can't see what the issue is. After 10 days of this issue and contacting support 4 times all I was left with was "I've done all the checks I can now, please monitor over the next 48 hours and of the issue persists contact us again".
So I've been monitoring it.
I've done some more digging and I've found the logs for the router which show a bunch of DNS name resolution errors, but also whenever the connection drops it says:
"Warning
DHCPC
WAN DHCP client (1) stopped"
Date/Time
23.06.2024 11:51:56
Severity
Info
Module
XDSL
Message
VDSL connectivity is up port 1
Date/Time
23.06.2024 11:51:14
Severity
Warning
Module
DHCPC
Message
Date/Time
23.06.2024 11:51:14
Severity
Info
Module
XDSL
Message
VDSL connectivity is down port 1
What can I do to get this fixed?
Any help appreciated, this is a big problem as I work from home and heavily rely on a good internet connection.
Thank you
14 REPLIES 14
Message 1 of 15
Hi Ld1111,
I've replied to your PM
Message 2 of 15
Hi Ld1111,
There are details of the potential charges here -  Engineers charges
You can PM (private message) me your availability if you prefer not to post it on the Community
Message 3 of 15
Yes it sounds like we need an engineer to come round as it is still the same if not worse now, but I don't understand what charges there may be?
Since we are paying a subscription to a service that we are essentially not getting, isn't an eventual engineer visit included, much like your efforts to help us with this technical support?
Also I don't feel perfectly comfortable sharing my availability on a public platform - how can we schedule that privately?
Thank you for your continued support
Message 4 of 15
Thanks for confirming. If the connection is still dropping at the test socket with 2 different routers then the next step would be to arrange an engineer visit to the property. If you'd like to go ahead with this then please can you confirm acceptance of possible time related engineer charges and also provide some availability AM (8-1) or PM (1-6) and we can book the engineer visit for you.
Message 5 of 15
Hi, yes we replaced all the cables with the ones that were delivered with the new router.
And yes it is still plugged in to that test socket and the connection is indeed still dropping.
Thank you for looking into this.
Message 6 of 15
I've re-checked your connection stats now and I can still see re-connections on the line. Just to confirm, is the router still connected to the test socket at the moment? When you connected the replacement router did you also replace the cables and microfilter?
Message 7 of 15
Good afternoon,
Thank you for confirming. I'll re-check your connection stats again first thing in the morning to see how the stability compares now that the router is connected to the test socket and will post an update.
Message 8 of 15
I've now plugged in the router to the socket under the panel.
Thank you
Message 9 of 15
Thanks for confirming. Would it be possible to connect the microfilter, router and phone (if you use one) directly at the test socket for 24hrs so we can see how the stability compares please.
Message 10 of 15
Thank you for your help.
I think it does, from other threads of sockets looking like mine it does seem that there should be a test one hidden in there, it's a 'Master Socket 5C'.
What should I do?
I won't be able to try things from my end in until later this evening.
Message 11 of 15
Thank you. I've run a test on the line now which is clear (shows router is off) but I can see re-connections on the line. Does your main socket have a test socket please?
Message 12 of 15
I've updated my details, hopefully you can retrieve the account in question.
Please note the router will be off today, but I'll be turning it back on tonight.
Message 13 of 15
  • Name
  • Telephone number
  • Alternative contact number
Message 14 of 15
This sounds like an unstable connection for some reason. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
