Internet dropping out
Gemma19935360
Message 8 of 8
Internet keeps dropping out at various point of the day. Raised a fault. Says its working on it. But also says my Internet connection is good? So which is it? I've done ALL the troubleshooting and it's made absolutely no difference.
G.Blacklock
7 REPLIES 7
Message 1 of 8
Yes, you can plug it in when it arrives and the wifi details will be on the back of the router.
Message 2 of 8
Thank you so I set it up as per instruction?
G.Blacklock
Message 3 of 8
Hi Gemma
Usual tests are currently passing but I can see some drops in the connection.
First thing to rule out is the router, so a new Hub is on the way to you.
Message 4 of 8
 let's not letting me show the picture. No wired connections to the router. And I don't have cables to test this.
G.Blacklock
Message 5 of 8
Your link to the image is broken, but your fault description tells me all I need to know.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
Gemma19935360
Message 6 of 8
 this is the back of my router. If this helps.
The light stays solid white.
It drops out and flashes orange.
Then switches to flashing between white and orange.
G.Blacklock
Message 7 of 8
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
