Internet drops and speed issues - unusable
TimWN
Message 10 of 10
Hi Team. I'm seeing slow downs again and multiple router reboots. Well below guaranteed minimum to an almost unusable speed and no stability.
A router reboot nor factory reset will help. Nothing changed in the house. I am checking the speed/stability on the router itself.
Had this several times in past and each time engineers (regular or ground works) cannot find a fault in the home. An engineer did do something on the local cab earlier in the week and since has been terrible.
Please can you check from your side as the online tool will not let me open a proper case with details and the service is unusable. Thanks.
9 REPLIES 9
Message 1 of 10
That's great news Tim, thanks for letting us know
TimWN
Message 2 of 10
Good morning Michelle
I'm pleased to report that connection has been stable for almost 2 days now and speed is back to 50Mbps.
Many thanks
Message 3 of 10
Morning Tim,
How are you getting on? Has there been any change since your last post?
Message 4 of 10
The line profile doesn't appear to be limiting your speed so I think it's worth trying the 30 minute shutdown again. Are you experiencing any problems with your telephone service, any noise on the line?
TimWN
Message 5 of 10
I did try this over the weekend to no avail. I can try this again tonight if something has been done on your side!
Message 6 of 10
OK thanks. Could you switch your router off and leave it off for at least 30 minutes, then switch back on and check to see if the speed has improved
TimWN
Message 7 of 10
Hi Chris
It has become more stable over the weekend it seems. The main issue I appear to have now is that since the connection has been up and down a lot the rate is capped to around 30 mbps.
Is it possible to force a reset? I was previously getting just over 50 for  months.
Chris-TalkTalk
Message 8 of 10
Hi TimWN,
How has it been since your post?
Gliwmaeden2
Message 9 of 10
Your thread is in the queue for attention, @TimWN  - but staff are not back before Monday.
