Internet keeps dropping/speed to devices poor
on 02-08-2022 09:35 PM
Message 3 of 3
The internet keeps dropping this evening, apparently there are no issues with the Internet. When I did a speed test it says the speed to the router is good but the speed to my device is poor ?
The internet is Usually connected to multiple devices and works fine ?
Katie Giles
Labels:
- Labels:
Connection
Speed
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 03-08-2022 07:44 AM
Message 1 of 3
Hi Katesqui333
The line test is clear and the sync speed looks ok.
Please can you run a wired speed test when the speed drops to see how this compares?
Are any devices connected uploading when the speed drops?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-08-2022 09:45 PM
Message 2 of 3
Hi @Katesqui333,
Is this affecting both wired and wireless devices (if you have both) ?.
What do the light(s) do on the router when you lose connection ?.
What model of router do you have ?.
If the light(s) on the router indicate it is losing connection with the internet....
It would be worth going to the Service Centre to run a connection test on your line (if you have not already done this), this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
