Issues with disconnects
JordanS
Message 35 of 35
A couple months ago I was having constant issues with DL speed drops. I reported this to Talk Talk many times to be told 'our test isn't detecting any faults' despite me contacting multiple times to raise the issue. They sent out a new router as I hadn't been upgraded, and this has since resolved the issue. However, since the new router I have been having regular disconnects when I get home from work, once or twice an evening. I'll be gaming and in Discord with friends, I disconnect from the game I'm playing, my voice goes "laggy" in Discord so I'm told, then I cut out, 10 seconds later I'm back like nothing happened. I'm on a wired connection to my PC, so wireless won't be the issue, although my wife has noticed similar issues and she is working on a wireless laptop, so there definitely appears to be an issue with the router in some way, as opposed to my line as I never had these disconnect issues previously, only when I had the new router to resolve the speed issues.
MR JORDAN K SAYLIK
34 REPLIES 34
Message 1 of 35
I'm really glad to hear this. I'm just sending you a short survey via a PM now.
Message 2 of 35
Hi @Karl-TalkTalk , touch wood, so far it's been all good since the firmware update. Will continue to monitor but yes it seems to have resolved it.
MR JORDAN K SAYLIK
Message 3 of 35
Hi JordanS
How has the connection been ?
Message 4 of 35
No problem. We will also check back in with you on Friday to see how the connection has been.
Message 5 of 35
Morning @Debbie-TalkTalk, thank you. I'm qt work in the office today but will monitor tonight and coming days to report back.
MR JORDAN K SAYLIK
Message 6 of 35
Hi Jordan
UPDATE.
The firmware has now updated, please can you let me know how the connection compares now with this router connected?
Message 7 of 35
Hi Jordan
Sorry for the delay.
I'm trying to make a change to the router firmware, is the router still switched on?
Message 8 of 35
@Debbie-TalkTalk  Just FYI, the new router is still disconnecting.
MR JORDAN K SAYLIK
Message 9 of 35
Hi @Debbie-TalkTalk , the new router is all connected now.
MR JORDAN K SAYLIK
Message 10 of 35
Hi Jordan
Could you connect the router again and I will check the firmware first.
Thank you.
Message 11 of 35
Hi @Debbie-TalkTalk , we can give it a try, could it also be firmware related on the current 'new' router that I have? I haven't personally updated the firmware and last time I tried on the old router I believe this is something only you guys can do now as the firmware isn't available to download online anymore from what I found previously.
MR JORDAN K SAYLIK
Message 12 of 35
Hi Jordan
Would you like me to send one more router for testing?
Message 13 of 35
With the old router speed drops frequently, too much for me to want to use. With the new one there are no speed drops, but disconnects instead.
MR JORDAN K SAYLIK
Message 14 of 35
Hi Jordan
Is the speed lower at certain times?
Message 15 of 35
Good morning @Debbie-TalkTalk , I can confirm that I've had the old router plugged back in for the last few days and I've had no disconnects, I've had speed drops as I previously did, but no disconnects.
MR JORDAN K SAYLIK
Message 16 of 35
Message 17 of 35
Hi JordanS
Ok no problem. I just wanted to check in with you.
Debbie 🙂
Message 18 of 35
Hello @Debbie-TalkTalk , haven't been able to switch it over yet, I'm working from home today so will give it a try when I finish later this evening, shall then monitor over the coming days and will report findings here. Thanks.
MR JORDAN K SAYLIK
Message 19 of 35
Message 20 of 35
Hi JordanS
Yes please if that's ok.
Thank you.
