on 13-06-2022 09:03 AM
This gets worse - cannot connect mt smart (samsung) TV because it asks for:
MAC address
IP address
Sub Mask
Gateway
DNS Server
Somebody from the community said that I did not need these cades as the TV would connect automaticly - well it does not after serveral attempts.
Also impossible to log on to my account for help - after entering e mail address and password the screen freezes after 30 seconds of tying to "connect" May have to go back to BT !!
on 13-06-2022 09:23 AM
Top tip: If your TV was connected to the former BT Hub via Wi-Fi then either:
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 13-06-2022 09:06 AM
are you connecting your smart tv via wifi or via a direct cable to the router?
