Losing DNS Connection
JJG_57
Message 28 of 28
I'm frequently losing connection to my DNS server. When this happens I can ping a known IP address e.g. 8.8.8.8 but if I ping something like bbc.co.uk it fails.
I can sometimes fix it by going to the router admin console and changing DNS providers, say from Talk Talk to Google and maybe back again. However sometimes I need to restart the router.
Sometimes it stays stable for several days, but other times it fails again within minutes. When it fails there are no error lights visible - the white light stays on as usual.
I have a Sagemcom router, firmware version SG4K10002829t
Any advice welcome.
27 REPLIES 27
Message 1 of 28
Message 2 of 28
OK will do. Many thanks for your help.
Message 3 of 28
Hi JJG_57
That's great, thank you 🙂
No you can just pop the older router and cables straight into the pre paid returns bag.
Thanks again.
Message 4 of 28
All seems OK so I will return the old router using the label supplied. Do you need me to mark the return with any reference number of ID?
Message 5 of 28
Message 6 of 28
Apologies, I thought I had posted an update yesterday.
I don't think we have had any DNS problems since I swapped the router over.
Updating the firmware seems to have resolved the problem with my work VPN.
So - all good so far thanks. I'll give it another couple of days to check that no issues have crept in after the firmware upgrade.
Message 7 of 28
Hi JJG_57
How's the connection been since the firmware updated?
Message 8 of 28
Hi JJG_57
Your router firmware has now updated to version 158.
Message 9 of 28
Hi JJG_57
Our Devices Team have advised that updates on the firmware should now be available within the next 2 weeks.
We are currently still experiencing issues updating the router firmware.
Message 10 of 28
Hi JJG_57
Apologies for this.
We are currently experiencing issues with firmware updates. This has been raised to our Devices Team and they are working to fix this.
Message 11 of 28
Just as an aside, I've just received an email saying "You've earned the Staying Active badge on TalkTalk Help & Support"
I don't want badges and I don't want to be active on a support forum - what I want is a reliable internet connection.
Message 12 of 28
I've been away but the new router has arrived and I have now connected it.
Its admin page says it is at version SG4K100136
This has reintroduced a problem I had more than a year ago with connection to my work VPN - see your ref REP-10835132 / Incident: 220207-000529
I do have a workaround for this which I can use temporarily so I will leave the new router plugged in for a few days and see how it goes.
Message 13 of 28
Hi JJG_57
Let us know once the new router is connected.
Message 14 of 28
I suppose it depends what the "issues" are that you are having. If it's possible that a different physical router will be able to be upgraded then it's probably worth a try. If the issue is that you can't get upgrades out generally then it probably won't help.
I have more urgent things to do right now but I will need to look at alternative ISPs if I don't see any progress in the coming few days.
Message 15 of 28
Hi JJG_57
I'm really sorry about this. I can send a new router but it wont have the new firmware on it, this has to be updated once the router is connected.
Message 16 of 28
I can't keep waiting for this. It's affecting our ability to work from home and my daughters' ability to revise for their exams.
If you can't upgrade my router remotely can you ship a replacement router with up to date firmware? Then we will at least see if that's the cause of the problem.
Message 17 of 28
Hi JJG_57
We are still experiencing issues with the firmware updates. I will post back as soon as I have further information.
Message 18 of 28
Hi JJG_57
JJG_57
Message 19 of 28
Yes it is.
Message 20 of 28
Hi JJG_57
Our Devices Team have asked me to check if your router is switched on at the moment?
