on 16-10-2023 12:38 PM
My speeds were showing low on test and I got the message to change channels. Following the instructions to change it my WiFi was disabled and I can't enable it now.
I have lost my WiFi from my laptop. My router is not listed in the available network connections. My smart phone is still connected ok.
Any help please.
on 19-10-2023 03:44 PM
That's great news jimbly, thanks for letting us know
on 19-10-2023 03:16 PM
Hello Debbie, new router just arrived. Plugged it in and everything was as it should be.
Thanks a lot.
Jimbly
on 17-10-2023 08:16 AM
Hi jimbly
Ahh no problem 🙂
Thanks again.
on 17-10-2023 08:06 AM
Hello Debbie, thanks for sorting that.
You're a star!
Cheers.
Jimbly.
on 17-10-2023 07:05 AM
Hi jimbly
No problem 🙂
on 16-10-2023 04:29 PM
Hello Debbie, that would be a good idea, if you can please.
Cheers.
Jimbly.
on 16-10-2023 02:23 PM
Hi jimbly
Would you like me to send a replacement router for testing?
on 16-10-2023 02:19 PM
Hello Debbie, missed this off, when I was following the instructions to change channels, the WiFi is showing as disabled on the hub connectivity page, even though I didn't get around to changing any settings. The enable/disable WiFi button is green, as are band 1 and band 2. But all showing disabled status.
Cheers.
Jimbly
on 16-10-2023 01:46 PM
Hi jimbly
The pin hole reset would reset the router back to default settings. This may help as you say this only happened when you changed the channels?
on 16-10-2023 01:42 PM
Hello Debbie, my smartphone is working ok, so didn't think that would help my laptop connection to the WiFi. My laptop doesn't even list my router in available connections.
Jimbly
on 16-10-2023 12:49 PM
Hi jimbly
Can I just check, have you tried factory resetting the router using the pin hole reset for ten seconds?
