on 29-04-2025 11:26 AM
Hi all, we're having some custom blinds fitted and need the junction box moving as it's on the window sill. The box connects our wifi and landline to the outside telegraph pole and literally needs the wire moving. Talk Talk have been clueless with their operators not knowing a thing. BT say it's TT we need to contact first and TT will talk to BT. Anyone else had this issue or any ideas how we can go about getting it moved without doing it ourselves, which is not supposed to be the done thing.
on 12-05-2025 02:49 PM
Perfect! Do not hesitate to get back to us if you need assistance in the future. Have a lovely day!
on 12-05-2025 02:28 PM
@sabelo-TT Thanks so much. Nothing else currently!
on 12-05-2025 01:24 PM
@Claris1 not a problem as I have scheduled your appointment on my end and have attached care notes to your account which will serve as proof of the appointment.
Now that this has been sorted, 🙂 Would there be anything else you would like for me to further assist you with apart from what we have discussed?
on 12-05-2025 11:50 AM
Hi @sabelo-TT That would work for us. Please go ahead and book. Thank you!
on 12-05-2025 11:41 AM
@Claris1, thank you for this as I do understand and attached notes to your engineer callup which will be able to assist with this.
So, I am now arranging an engineer which will come to your home and move the box. Upon further checking, I can confirm that I managed to find a slot for 13/05/2025 which will be tomorrow between 09:00am - 12:00pm. Sounds fine with you @Claris1?
on 12-05-2025 11:07 AM
Hi @sabelo-TT Maybe a bit of confusion by me calling it 'junction box'. The main junction box doesn't need to be moved. It's the smaller one that feeds the wire into it we need moving. We need the box and wire moved from the window sill. I've highlighted the one that needs moving in the attached image. Hopefully makes a bit more sense. Thanks!Box that needs moving
on 09-05-2025 04:47 PM
@claris , thank you for this.
In order to help us determine the right engineer needed, we will need to know where you would like to move the master socket to.
Would you like to :
Or would you like to :
on 09-05-2025 04:07 PM
Hi @sabelo-TT It's the NTE 5C. I've also attached image. Thanks!NTE 5C
on 08-05-2025 01:59 PM
Thank you for confirming this to me @Claris1. I will just need to know one thing before I proceed forward with this.
I need to find out what type of master, or main, telephone socket you have so I can give the correct troubleshooting advice. The master socket will be a white box on a wall, and is where the telephone line connects into your house from outside. Please browse to https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432 - this page shows you images of the different socket types so you can identify which you have.
Alternatively, you can share an image of the master socket to me.
on 08-05-2025 11:29 AM
Hi @sabelo-TT We understand there's a cost and that's fine. Could you tell us please how we can go about getting this booked in? Thank you.
on 08-05-2025 08:52 AM
Hello there @Claris1,
Just wanted to double check on the matter with the moving of equipment to your home. Please note that this will need engineer intervention as it will also entitle a charge.
on 30-04-2025 12:13 PM
Thanks @sabelo-TT updated profile with account number. If it helps this is a picture of the box/wire we need moving.Junction box on window sill
on 29-04-2025 12:25 PM
@Claris1, yes, it would have to be done through Talktalk organising it for you to fix up the appointment with Openreach.
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
Staff should be able to confirm whether it's the same charge for moving a junction box as a typical ONT / Mastersocket etc
on 29-04-2025 11:40 AM
Hello there @Claris1, thank you for making us aware of this as we will be able to look into for you.
Firstly, please update your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
