on 17-01-2022 09:41 PM
Can anyone help me please? I have just changed from ee to TalkTalk however my laptop wont connect to the router. It sees the wifi but when I click to connect it doesn't prompt me for a password it just does nothing. My laptop connects to other routers fine but not this one. All other devices in the house can connect to my router except this laptop. I have tried updating the wifi drivers and still nothing can anyone help please?
21-01-2022 11:38 AM - edited 21-01-2022 11:42 AM
When you updated the Wi-Fi drivers did you install some specific driver you had downloaded, or did you just let windows find and install the drivers it thought were best. I've had issues in the past (not with network drivers, but with other drivers) where I had installed a new version from the vendors website, but windows was actually more stable with the older version of the drivers that were delivered by the windows update process.
Mind you, if you had the same issue with an external USB Wi-Fi adaptor, then maybe it is not a driver specific issue, as presumably that would have been shown as a different device with different drivers.
on 21-01-2022 11:30 AM
So it has to be an issue with Windows 8 then. The only help I could offer from now on would be via Google searches that you have probably already done, as I have never had V8. I went from Windows 7 to Windows 10, as there was a lot of negative press at the time concerning that version.
on 21-01-2022 11:15 AM
As it happens yes 🙂 Tried it and exactly the same 😞
on 21-01-2022 11:11 AM
Do you have a spare USB WiFi adapter that you could try?
on 21-01-2022 11:02 AM
Thanks Keith, I did do quite a bit of due diligence before putting a flag up here 🙂
That article was one I worked through. It's killing me this to think I've got super speed broadband now, but the only way I can access it from my main laptop is if I link my laptop to my phone first 😞
on 21-01-2022 10:57 AM
Whilst I haven't had a chance to read this article, I did a quick Google search & came up with this:-
https://windowsreport.com/wi-fi-wont-ask-password-6-quick-solution-fix-problem/
on 21-01-2022 10:49 AM
Away from the pc at the moment I work. Don't think there's an option to forget it's never logged onto it in the first place.
I'm sure I've looked in the past at doing that but its not an option. It sees the network as available but won't log on to it.
on 21-01-2022 10:43 AM
In that case, tell Windows to forget the network. That way it should force you to enter a password.
on 21-01-2022 10:30 AM
It won't give me an option to enter a password at all. That's the problem.
on 21-01-2022 09:03 AM
There is nothing obvious there. I know this won't be the case, but I assume that you are using the correct wireless password?
Moving on from this I can only assume that either the driver being used is not correct for Windows 8, just because you connected to other routers, that may have been on the other WiFi band to the one that you are trying to connect to now, or there is too much WiFi interference on the band that you are trying to connect to at home. If you would like my help to identify levels of such interference, let me know.
on 20-01-2022 06:05 PM
Thanks for trying to help out again Keith
No updates have been done to the laptop. I was happily using it to connect to my old ee router and several other wifi routers at work. I was never in the habit of updating windows anyway but I thought I would now to see if that made any difference and would help (its been years :D), but it didn't its still the same even after updating windows.
And I did as you said here
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>netsh wlan show drivers
Interface name: Wi-Fi
Driver : Intel(R) Dual Band Wireless-AC 7265
Vendor : Intel Corporation
Provider : Intel
Date : 07/11/2019
Version : 19.10.21.1
INF file : C:\WINDOWS\INF\oem108.inf
Files : 3 total
C:\WINDOWS\system32\DRIVERS\Netwbw04.sys
C:\WINDOWS\system32\DRIVERS\Netwfw04.dat
C:\WINDOWS\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Vendor defined Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
IHV service present : Yes
IHV adapter OUI : [00 80 86], type: [00]
IHV extensibility DLL path: C:\WINDOWS\System32\IWMSSvc.dll
IHV UI extensibility ClSID: {1bf6cb2d-2ae0-4879-a7aa-a75834fbd0e3}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
on 20-01-2022 09:44 AM
Have there been any updates on your PC lately?
Please open a command prompt window by going to:-
Start > Accessories > Command Prompt
Please enter this command, pressing enter after each one and wait for the response. Then copy and paste the output into your reply.
Then I will be able to see both the driver information & the WiFi chipset of the card.
on 19-01-2022 09:29 PM
Looked in the windows event log and it's not pulling up anything unfortunately. I've tried clicking it while the log is open as well to see if anything new shows and it doesn't. I can't understand why every other device in the house will connect but not this one. I had no issues with my last ee router with this laptop and it connects via my phone as a hotspot as well no issues. But I can't keep relying on my phone as a wifi hot spot 😞
on 19-01-2022 06:42 PM
OK thanks agafor your help Skynet
And will look at that when I get a chance. It will contect via phone as a hot-spot though, it doesn't crash then. Will check and update.
on 19-01-2022 06:32 PM
From that video it looks like Windows Explorer might be crashing and restarting, as it redraws all of the icons on the taskbar when you try to join the network. Are you able to look in the windows event log to see if there is any error in there that might help narrow down the cause.
on 19-01-2022 05:48 PM
Thanks for taking the time to come on board and help out with a possible solution Keith. As I appreciate everyone else's input as well.
Work has been so manic at the moment I have been struggling to get onto trying to resolve this so my updates and input here has been a bit slow and limited.
To answer those questions about the router and wireless adapter in the device.
I have an i7 machine running windows 8.1 a Lenovo ThinkPad yoga. The wireless adapter in this machine is an Intel (R) Dual Band Wireless-AC 7265.
As for the router itself its a DG8041W-2.T5
This shows what happens when I try to connect.
on 19-01-2022 08:53 AM
@Anonymous has asked me to help you. What make/model of router are you using as well as the make/model of WiFi card in the pc?
on 19-01-2022 08:02 AM
on 19-01-2022 07:37 AM
The router just will not prompt me for a password even though it sees a full WiFi signal connection.
on 19-01-2022 07:34 AM
I haven't resolved this yet due to extended work commitments and this maybe the case again tonight.
I do need to get this resolved and won't go away and will update here as soon as I do.
I did have a quick look at splitting the channels last night but I could not see an option to rename the two just the main channel in general. I will get back to this as soon as I can.
All other laptops can connect to it except this windows 8.1 machine and as its my main laptop its very frustrating. I can connect to the Internet via my phone as a hot spot but this is less than ideal as I don't want to go through my phone everytime I connect to the Internet.
Will be back to resolve this.
