No WiFi flashing red light
Danielalexander
Message 23 of 23
No WiFi and flashing red light on box. Who can I contact?
D alexander
22 REPLIES 22
Message 1 of 23
openreach have confirmed resolution of the fault.
Can you please retest and let me know if there are any further issues.
Message 2 of 23
Hi Daniel,
This is still in hand with Openreach, no further updates yet. I'll check again later
Message 3 of 23
Hello, the WiFi still isn’t working. Have you got any new info regarding what’s happening? I’ve had nothing since going live on Tuesday and was on this chat and emails all yesterday trying to get it fixed.
D alexander
Message 4 of 23
difficult to give a timescale until the cause is identified, but openreach should be out within 24 hours.
Message 5 of 23
Yes, that is correct. What is the timescale to get this fixed?
D alexander
Message 6 of 23
I can see this has now been logged out to Openreach for investigation by our customer service colleagues last night.
Message 7 of 23
Hi, I’ve tried a working land phone there’s no connection working. It’s a BT open reach connection on wall if that helps also
cheers Danny
D alexander
Message 8 of 23
As everything looks OK from our end but not from yours then I think you most likely have a crossed line. If you can get hold of a phone and have a dial tone then dialing 17070 from the handset will read back the telephone number. If you have a crossed line then it will readback a telephone number that isn't yours. If it reads back your number then you don't have a crossed line and something else is the issue
Message 9 of 23
What’s are the two outcomes in the phone has a dial tone or not? In the 5-6hrs I’ve hoped this was fixed all you’ve offered is to switch it on and off and now borrow a land phone that nobody has used in about 20years. In your experience what’s do you think is wrong with the connection?
D alexander
Message 10 of 23
Are you able to borrow one of friend or family? It's just that it really would help us identify where the problem is
Message 11 of 23
No sorry no phone handset. I’ve not had one for about 20years.
D alexander
Message 12 of 23
Thanks for trying that. Do you have a telephone handset that you can connect to check the line? Your router is still showing connected at our end so you may have a crossed line?
Message 13 of 23
Hi, switched it back on. Still red light flashing, internet is connecting on mobile but saying “no internet connection”  in iPhone settings WiFi.
D alexander
Message 14 of 23
The router is showing that it connected yesterday morning and is still connected, line test passes. Could you switch the router off and leave it off for at least 30 minutes then switch back on and check to see if you then have an internet connection
Message 15 of 23
It hasn’t, was supposed to go live yesterday but still not. Done all the usual stuff to reset it but no joy. Been on 2 live chats since 9am, both disconnected. It’s same set up as TalkTalk box at work so confused why it’s not started working here
D alexander
Message 16 of 23
OK. The router is showing connected to the Internet at the moment, when was the last time that it worked?
Message 17 of 23
I’ve not got a landline phone connected. Only use mobiles
D alexander
Message 18 of 23
Is your telephone service working OK, is there a dial tone?
Message 19 of 23
Yes
D alexander
Message 20 of 23
Thanks. Is t he orange light flashing at the moment?
