NordVPN Stopped working overnight
mpscott
Message 8 of 8
Our home VPN and my son's work vpn stopped working overnight on Wednesday. Both are based on or are versions of NordVPN. Both work over a mobile data connection. My work VPN works fine.
Reading other posts this seems a common problem that requires a new router. Please confirm and advise how this is organised?
Mike
7 REPLIES 7
Message 1 of 8
Hi Mike
The firmware has now been updated. Please can you retest and let us know how you get on.
Debbie 🙂
mpscott
Message 2 of 8
Hi Debbie
Thanks for the prompt reply. Please go ahead.
Mike
Mike
Message 3 of 8
Hi mpscott
Sorry for the delay.
I can make a change to the firmware on your router which should resolve this issue. Are you happy for me to do this today?
mpscott
Message 4 of 8
Hi Keith
Apologies my error - I got the lable info from a photo I took yesterday and had forgotten it was off the old router I had taken out to see if that would work (it would not even connect 😞 ) So no I was not using the HUAWEI: HG633
The router actually in use and with the issue is the Sagemcom model.
Mike
Message 5 of 8
So are you using both the HG633 and the Sagemcom then?
The Sagemcom, having just upgraded to V130 is most likely the problem. Whilst this works fine with most VPN clients the Windows 10/11 built-in VPN clients and a few others will not work. This is further complicated by a separate Windows Update recently that blocked the built-in ones from working.
I have asked one of TalkTalk's support to pick your thread up and rectify this for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
mpscott
Message 6 of 8
Hi Keith,
From the label on the router:-
HUAWEI: HG633
Hardware Version: H.1.01
From the UI:-
TalkTalk Wi-Fi Hub
version SG4K100130
Firmware Version: SG4K100130
Device Info
Serial Number N7193264N009629
Hardware Version FAST5364 3.00
Software Version SG4K100130
GUI Version 5.6.1
Thanks!
Mike
Mike
Message 7 of 8
What make/model of router are you using & which version of firmware is it running?
