on 09-08-2025 11:33 AM
When is TalkTalk going to resolve their issue with the Patreon website and images being blocked? I use Patreon on a daily basis and completely fed up with this issue. I know I can use a VPN but that is not the point . I feel that a company like TalkTalk should be able to resolve this ongoing problem.
on 11-08-2025 03:10 PM
Hi @Shirltay1 Thank you for reaching out and sharing your concerns regarding the issues with accessing the Patreon website and images. I sincerely apologize for the frustration this has caused you, especially as a daily user of the platform.
The Patreon website is currently blocked due to a virus detection identified by our security protocols. This measure is in place to protect our users from potential threats. Unfortunately, we are unable to unblock the website at this time.
on 11-08-2025 02:36 PM
The issue has been escalated, and I will update you.
on 11-08-2025 01:18 PM
Thank you, please bare with me for a few minutes.
on 11-08-2025 12:56 PM
Yes, no problems with other networks or using mobile data.
on 11-08-2025 12:51 PM
When using other networks, you are able to view and download the page right?
Kanya
on 11-08-2025 12:25 PM
Accessing the website has never been the problem. Interestingly I have just found this :
on 11-08-2025 12:06 PM
But you can access the site now?
Kanya
on 11-08-2025 12:01 PM
Done that and still not able to open images , attachments
on 11-08-2025 09:11 AM
Thank you! I've activated this website on your Kidsafe settings, so let's see if that makes a difference. In the meantime, please clear your browsing history and cache, then restart your router. After that, try accessing the site again.
Kanya
on 11-08-2025 09:04 AM
on 11-08-2025 09:02 AM
I understand. Can you send me the exact URL link you are using to access this website. Kanya
on 11-08-2025 09:01 AM
No, I have this turned off. It will only work if I turn off Homesafe completely ie Virus and scam protection. If there is a virus being detected, then why is it only Talktalk that has the issue, as far as I know no other provider is blocking these images etc
on 11-08-2025 09:00 AM
And can you send us the URL link you are using to access this website.
Kanya
on 11-08-2025 08:55 AM
Do you have your Kidsafe on?
Kanya
on 11-08-2025 08:44 AM
Yes, it’s so frustrating!
on 11-08-2025 08:16 AM
on 09-08-2025 02:23 PM
Oh, and best to restart the router after whitelisting a site, preferably for 30 minutes to start a new session.
on 09-08-2025 02:11 PM
I'm not suggesting turning it off but adding the site to the allow list.
Good luck.
on 09-08-2025 01:59 PM
Thank you. I did try turning off kids safe and made no difference but will try again .
on 09-08-2025 01:49 PM
A quick Google search suggests Patreon allows 18+ material and it's probably for this reason kid safe blocks content.
