on 09-08-2025 11:33 AM
When is TalkTalk going to resolve their issue with the Patreon website and images being blocked? I use Patreon on a daily basis and completely fed up with this issue. I know I can use a VPN but that is not the point . I feel that a company like TalkTalk should be able to resolve this ongoing problem.
on 09-08-2025 01:46 PM
Then that is the issue. I don't so tried logging in and could view all content.
Not sure why using kid safe should be an issue.
Under specific sites in your home safe set up, have you added Patreon and then clicked allow? If not try this.
Guide can be found here.
on 09-08-2025 01:38 PM
Yes, I do use Home safe & Kid safe.
on 09-08-2025 01:31 PM
Do you use home / kid safe?
If not then the advice offered in your previous thread by @Divsec is still your best bet.
on 09-08-2025 12:52 PM
The only way I solved it was by using a VPN but that is not the point as I don’t want to have to continue to access the site by this method. I know I am not the only TalkTalk customer experiencing this problem. I don’t know of any other provider, other than TalkTalk , who are blocking content on Patreon.
09-08-2025 12:42 PM - edited 09-08-2025 12:43 PM
From a previous thread it appears you solved this by switching DNS servers.
Did you switch back?
TalkTalk must think there is an issue to block it so for the majority of customers this is still the issue and they continue to protect their customers accordingly.
