on 27-07-2022 09:10 AM
Message 21 of 21
The connection between the router and my new ring doorbell is really poor, it reads RSSI-74 and the live view is very erratic, the white light on my router is dim and not sure if this is relevant to the problem. I’ve moved the router to the nearest point to the door but it doesn’t make any difference. Any advice would be appreciated.
Answered! Go to Solution.
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
20 REPLIES 20
on 28-07-2022 12:44 PM
Message 1 of 21
optimisation is now turned off.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 12:37 PM
Message 2 of 21
Thanks again Chris ,
I think it seems that is the best option, at the moment so go ahead and I will attempt to change the channel at a later date.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 11:08 AM
Message 3 of 21
Disabling it will just stop it automatically changing your channel, the channel will just remain the same unless you manually change it of reboot the router. If I don't disable it then when you change the channel, optimisation will probably change it back again shortly after - would you like me to go ahead?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 10:49 AM
Message 4 of 21
Thanks for you patience Chris,
If it doesn’t interfere with my settings would this be the best option and I assume disabling it wont have any effect if I revert back to the original channel.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 09:47 AM
Message 5 of 21
There's instruction here explaining how to change wifi channels - Change your wireless channel - TalkTalk Help & Support
Would you like me to disable wifi optimisation? This will just stop the router automatically changing your wifi channel once you've changed it
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 09:32 AM
Message 6 of 21
Ok thanks Chris,
What is the procedure as I don’t want to mess up my settings.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 09:24 AM
Message 7 of 21
OK thanks. All I can really suggest is trying different wifi channels to see if you can get one with a better signal
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 09:21 AM
Message 8 of 21
No radiator, the lead to the router is at it’s maximum length to about 1/2 metre from the end of my internal wall, the only obstruction would be a lounge door and the front door. Hope this helps.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-07-2022 08:49 AM
Message 9 of 21
OK thanks. Are there any metal objects between the router and the doorbell, such as a radiator?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 05:52 PM
Message 10 of 21
Thanks Chris,
I think I’ve misread your comment on changing WI Fi channels, it was a reset on the Ring doorbell, so I don’t feel confident enough to change the router channel.
As an update I reset the doorbell indoors and the RSSI decreased to -45 so I guess the signal isn’t strong enough to reach outside.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 02:34 PM
Message 11 of 21
We can always enable it again but it's up to you if you'd like to try it or not, it just allows you to select your own wifi channel without optimisation interfering
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 01:33 PM
Message 12 of 21
Not sure what the implications would be as I don’t want to lose the good connections with my other devices which might lead to more complications.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 01:31 PM
Message 13 of 21
Not sure what the implications are as I don’t want to lose the good connections with other devices and if it leads to more problems.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 01:26 PM
Message 14 of 21
I could try disabling wifi optimisation, this will stop the router automatically changing channels and allow you to try different channels - would you like to give this a try?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 01:21 PM
Message 15 of 21
Thanks Chris , tried but no difference.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 11:42 AM
Message 16 of 21
Have you tried changing the wifi channel?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 10:52 AM
Message 17 of 21
No it’s not close to any that could cause interference.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 10:46 AM
Message 18 of 21
OK thanks. Is the router situated close to other devices that could be causing interference?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 10:23 AM
Message 19 of 21
Hi Chris,
Approximately 3 metres away from where the bell is mounted and only one wall. Hope this helps.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-07-2022 09:55 AM
Message 20 of 21
Hi Cosmo,
Approximately how far is the doorbell from the router? How many walls are there between the router and the doorbell?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
