Replacement router not arrived
Emmelph
Message 5 of 5
My router stopped working and i was told that a new one would be sent out. Its a week later and im still without a router.
4 REPLIES 4
Message 1 of 5
OK thanks. I've ordered a router, it should be with you within a couple of working days, apologies for the delay
Emmelph
Message 2 of 5
Theres no obvious damage but it wont switch on. Theres no light on the front and no wifi connection
Chris-TalkTalk
Message 3 of 5
Hi Emmelph,
Could I ask what the problem is with your current router?
Divsec
Message 4 of 5
Hi @Emmelph your post has been escalated and the team will be with you shortly.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
