Router Wifi Issue
randomuser5673
Message 32 of 32
My router's wifi keeps losing internet access for all my devices but they can remain connected to the wifi. Devices connected via LAN work fine. The router still has a white light on the front. If I reset the router the wifi works for a bit but then the issue happens again.
Please help me!!!!
Jack
31 REPLIES 31
Message 21 of 32
Do you have any wired connections experiencing issues or only wireless?
randomuser5673
Message 22 of 32
Thanks Debbie, the firmware fixed the vpn issue for couple of hours. However now the original issue of the Wi-Fi not having internet access has occurred. I have not yet done a reset on the router.
Message 23 of 32
Apologies, I've made a change to the router firmware. Please can you retest?
randomuser5673
Message 24 of 32
Hi Debbie,
The new router has arrived and I can now connect to the internet again, but unfortunately it I cannot use my work's PPTP VPN. It says that "A connection to the remote computer could not be established, so the port for this connection was closed". I had the same error message with the previous router 6 months ago after a firmware update. The router was then rolled back to a better version and the issue was resolved.
Please can you advise if you can do the same/fix it another way?
thanks !
Message 25 of 32
randomuser5673
Message 26 of 32
Hi Debbie,
Thank you for your help with this. I will be in touch after i have set it up.
Message 27 of 32
No problem 🙂
Thanks again.
randomuser5673
Message 28 of 32
Yes please that would be great 🙂
Message 29 of 32
Thanks for confirming this.
I'm unable to connect to your router. Would you like me to send a replacement router for testing so we can rule this out?
randomuser5673
Message 30 of 32
Hi Debbie,
Yes I did, the issue went away for a while (2hrs) and now its back 😞
Message 31 of 32
Hi randomuser5673
Did you factory reset the router using the pin hole reset for ten seconds?
