on 19-01-2025 01:51 PM
My router is constantly resetting and losing all settings which is very problematic for connected WiFi devices. The duration between resets is quite sporadic, sometimes I get a few days of continuity and other times it resets multiple times in a day. Please advise.
on 27-01-2025 01:16 PM
Thanks for confirming.
on 27-01-2025 01:13 PM
I've been using the new router for a few days now and it seems to have resolved my issues. Thank you for both of your help!
on 20-01-2025 09:13 AM
A new router is on the way for testing.
on 19-01-2025 03:25 PM
That is even more ancient, let's get it changed out.
on 19-01-2025 03:22 PM
Thank you. I have the HG635 Super Router.
on 19-01-2025 03:18 PM
Is your router the DG8041W by any chance, as this can reboot itself without notice? The only solution is to change it to a Sagemcom FAST 5364. If you have any other router including the 5364, then perhaps it is faulty.
