Router faulty
retired2000
Message 6 of 6
Hi, I've reported a fault now active under reference 11186335. The problem is weird. The router is a DG8041W-2.T5 kindly supplied by TT when my contract was renewed 21/01/ 2022.
It connects to the Internet perfectly and the WiFi works fine. What does not work at all are the LAN sockets which give no access at all.
I have reset the router, by holding the reset button in for thirty seconds, releasing, and allowing the router to reboot, but the problem persists. What I would appreciate is a replacement router. Please could these details be passed on to Service/Support team? Thank you.
David. Interested in mending things electrical and mechanical.
5 REPLIES 5
Message 1 of 6
Hi David
Ahh you're welcome 🙂
Debbie 🙂
retired2000
Message 2 of 6
WHAT SERVICE!!!! That's brilliant Debbie. Can't thank you enough. David.
Message 3 of 6
Hi David
The router is on its way and a pre paid returns bag for your current router.
Please allow 24-48hrs for this to arrive.
Debbie 🙂
retired2000
Message 4 of 6
Dear Debbie, Thank you so much for your instant response. I've updated my profile with my name and TT landline number. I very much look forward to receiving a replacement router and thank you for your decision to send one. Should I return the present one, and power supply, to you? Kind regards, David
Message 5 of 6
Hi retired2000
Please can you update your Community Profile to include your name and TalkTalk landline number, I can then send you a replacement router.
