on 27-06-2022 06:26 PM
My router seems to have stopped working. I've reset it many times and it doesn't connect and the lights go off and it doesn't show up as available on any of my devices. Any help would be appreciated.
Sean
on 29-06-2022 04:08 PM
That's great news, thanks for confirming.
I've also sent you a quick PM.
on 29-06-2022 04:05 PM
Hello there,
I have received the new router and everything is working as it should, many thanks for the help.
on 28-06-2022 03:07 PM
Router will be with you in the next day or two, please post back after it arrives and let us know if this has resolved the issue 🙂
on 28-06-2022 03:05 PM
Thanks Debbie, I'm sure that my router has died so this will fix my problem.
on 28-06-2022 07:01 AM
Hi Scraggio
Apologies for this.
I have ordered you a replacement router for testing, please allow 24-48hrs for this to arrive.
on 27-06-2022 08:13 PM
Not really, the only thing connected to the router is my ps5 which is not connecting to the internet or even showing up as connected to the router. Have had my case escalated to a manager but I suspect the router has gone kaput
on 27-06-2022 08:00 PM
OK, are you able to try a wired connection at all?
on 27-06-2022 07:30 PM
I have been on chat with support and they are currently running tests on the line. Its just strange that I can't see my router as a wireless device even though I have been able to before even when its not been able to connect to the internet.
on 27-06-2022 06:53 PM
Have you checked if your landline is working as normal? Have you tried connecting your router directly to the test socket if you have one? The support team here will pick this up as soon as they can when they are back online tomorrow.
