Router issues
Deanoholden
Message 13 of 13
Hey there,
For the last couple of days my router (Sagemcom-FAST5364) has been randomly restarting on it's own. Up until now that hasn't caused any issues but so far today it has restarted 5 times, and each time the "current speed" on the device admin pages, and on the connection speed test on the TalkTalk website has dropped.
A few days ago I was getting well over my guaranteed speed of 46Mbps at around 59Mbps which it has been at pretty consistently for over 12 months. Today, with each restart the speed has dropped so that I'm now currently getting around 22Mbps.
There are no issues reported in my area, my connection is testing as OK on the TT website. Do I need to request a replacement router as it seems to be the restarts causing the speed drop?
Deano
12 REPLIES 12
Message 1 of 13
Hi Deanoholden
No problem, I've ordered one for you now.
Please allow 48hrs for this to arrive.
Message 2 of 13
No, there was no returns bag. It just came with instructions for a new customer.
Deano
Message 3 of 13
Hi Deanoholden
That's great 🙂
Did you receive a returns bag with the new router?
Deanoholden
Message 4 of 13
@Michelle-TalkTalk I've got it set up. Things seem fine so far. What should I do with the old one?
Deano
Message 5 of 13
Ok, no problem. We'll check back in with you tomorrow to see how you're getting on.
Message 6 of 13
Not yet.
Yodel tracking says it should be delivered sometime today.
Deano
Message 7 of 13
Can I just confirm, have you received the replacement router?
Deanoholden
Message 8 of 13
@Karl-TalkTalk Interestingly, while the main page on the router keeps resetting the counter for how long it has been connected, the 'system up time' looks like it's at 17 days which implies it isn't restarting the box, just restarting the connection so I may have misunderstood.
The only other clue I have is in the logs which seems to say the following at each point when the connection resets, although my devices are disconnected at lot longer than these timestamps indicate.
14.04.2023 14:31:35InfoDHCPC
WAN DHCP client (1) started
14.04.2023 14:31:32InfoXDSL
VDSL connectivity is up port 1
14.04.2023 14:31:08WarningDHCPC
WAN DHCP client (1) stopped
Deano
Message 9 of 13
You're Welcome 🙂
Deanoholden
Message 10 of 13
Thanks @Karl-TalkTalk, much appreciated. Fingers crossed it resolves it.
Deano
Message 11 of 13
Tests are clear, so no visible issues stand out. I'll get a replacement router out to you and see if that is the issue.
Deanoholden
Message 12 of 13
...and it has just restarted again, remaining at 22.5 Mbps. But this is painful as every restart is disconnecting me from work calls.
Deano
