on 11-03-2025 02:09 PM
Just received an email about my router being no longer supported. Can I be supplied with a router that is supported because I am not happy at no longer getting security updates. I have been a customer since talktalk began and had my current router for many years. Recently I have been having to restart it because of connection problems and I suspect, having received the email, that lack of updates may be the cause.
on 12-03-2025 06:51 AM
on 11-03-2025 10:12 PM
You're very welcome.
Thanks Keith and Chris for your quick response, it is much appreciated.
on 11-03-2025 03:43 PM
Hi Lang+g,
As you are experiencing problems with your service I've ordered another router to test with, it should be with you within a couple of working days
on 11-03-2025 03:24 PM
I have asked one of TalkTalk's support to pick your thread up and replace it for you with a Sagemcom.
on 11-03-2025 03:22 PM
HUAWEI DG8041W
on 11-03-2025 03:01 PM
That shouldn't be a problem, which make/model of router do you have currently?
