SAGEMCOM FAST 5364 - Hacked firmware
Jolnir
Message 16 of 16
I think someone has hacked my router at the route level and enabled a bunch of sureillance settings and custom firewall settings utilising the exploit located at this url: https://github.com/shiroiokami85/talktalk_fast_5364
This exploit allows SSH for P2P remote surveillance, various sites aren't loading properly after factory reset and firewall resets on my computer, very specific political sites that aren't banned or restricted in the UK.
I've added a screenshot of my firmware, I think autoupdate has been disabled too. Is there any way I can get a link to the latest update to manually update my firmware or perhaps a new router?
15 REPLIES 15
Message 1 of 16
Hi @Jolnir
No problem 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 16
Ok perfect thank you
Message 3 of 16
Hi @Jolnir
That's great, thanks for letting us know 🙂
I've just updated your router firmware to the latest version.
Thanks again.
Jolnir
Message 4 of 16
Hello all
My new router has arrived and I wondering if you could check/force a firmware update
Message 5 of 16
Good afternoon,
How are you getting on?
Message 6 of 16
Ok
Message 7 of 16
Hi Jolnir
Please let me know (here) once the new router is connected and I will check the firmware.
Message 8 of 16
Yeah lets do that. Will it come with the latest firmware?
Message 9 of 16
Hi Jolnir
Ok, would you like me to just replace the router?
Message 10 of 16
I did it before contacting and the hackers adjustments remained
Message 11 of 16
Hi Jolnir
If you factory reset your router using the pin hole reset for ten seconds then this will set the router back to default settings.
Please can you try this before we do the firmware update.
Message 12 of 16
I'm concerned that the root level adjustments might remain intact after a firmware update, can you confirm if this is the case or not? Otherwise go ahead with the update.
Message 13 of 16
Hi @Jolnir
We do have new firmware available. Will it be ok for me to update your firmware now?
We advise to leave the router switched on without rebooting whilst we update the firmware. It should take no longer than 15 minutes to update.
Message 14 of 16
Done
Message 15 of 16
Hi Jolnir
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
