Sagecom Fast 5364 port forwarding and vpn issue
katblue2022
Message 6 of 6
I have been having alot of issues since the recent formware update on our router.
I am no longer able to forward any ports to local machines on my network or connect to any vpn connections.
I had no issues with this before but now even after factory resetting my router and every possible fault finding exercise i can think of my router will not allow me to forward any ports or connect to a vpn.
kind regards
5 REPLIES 5
Message 1 of 6
katblue2022
Message 2 of 6
Thank you very much your support is appreciated i will check that for you now and will let you know once i have tested.
Much Apreciated
Kind Regards
Message 3 of 6
Hi katblue2022
All done, your firmware has been updated.
Please can you retest and let us know how you get on.
Debbie 🙂
katblue2022
Message 4 of 6
Afternoon Debbie thank you for you prompt reply to my issue. that will be fine thank you your help is much appreciated.
i am assuming my router will reboot itself once the firmware has been changed.
Kind Regards
Message 5 of 6
Hi katblue2022
Apologies for this.
I will need to make a change to the firmware on your router.
Will it be ok if I do this today?
