on 18-03-2025 10:54 AM
When I switched to fibre I was sent a Saemcom router but the Huwaei DG8041W router seemed to be doing just fine and has been working for some time. Something has come up and I need to port forward ports 80 & 443 apparently there is an issue with this on the DG8041W. Can I just switch the routers without causing any problems with connections? I am aware that I will have to change the WIFI passwords. The Saemcom does not seem to have come with a power supply does this use the same one as the DG8041W. Can I switch back to the DG8041W if the is an issue?
on 18-03-2025 01:29 PM
You're Welcome 🙂
on 18-03-2025 01:18 PM
Karl-TalkTalk thanks for the help.
on 18-03-2025 10:56 AM
You can switch router. Not sure about the power supply from the DG8041 working with the sagemcom, but any issues and you can swap back.
