Unstable broadband
daveonmako
Message 13 of 13
I am hoping you can help me with an issue I've been experiencing for some time with my broadband service. On a regular basis (every 2 days or so) my internet connection drops and I get an orange light on my router. Usually, it will reconnect after a short while (up to 30 minutes) or a router reboot but will often disconnect again within an hour. There have always been stability issues with my service but I put it down to the additional load on the service due to so many people working from home and kids having to home school. However, since the kids have gone back to school and people are returning to the office the service is actually getting worse.
I suspect the issue is with my router as when I perform a health check there are no issues detected on the line but the orange light would suggest loss of connection to the internet. Wifi and wired connections to the router remain connected but obviously, there's no internet for devices to make use of.
TalkTalk's support would be appreciated with this issue.
Thank you
12 REPLIES 12
Message 1 of 13
I'm sorry to hear this. Would it be possible to connect the microfilter, router and phone directly at the test socket so we can see how the stability compares please?
Message 2 of 13
Hello, Michelle
Sorry, I had not realised I had missed a reply.
No, the router is connected to the normal port.
I have had a further 3 disconnections today where I've lost internet for a couple of minutes and then it has returned. Normally not a problem, today, however, I was taking an online exam as part of a certification programme with work when the internet dropped and I was disqualified from the exam.
EDIT: My internet has disconnected twice since I posted this message 30 minutes ago ☹
Message 3 of 13
I'm sorry to hear this. I've re-run the line test now which hasn't detected a fault, however I can see a few re-connections on the line. Is the router currently connected at the test socket?
Message 4 of 13
Hi, Chris
Just to update as requested. My internet has been stable until today. However, it has disconnected 4 times in the last hour or so ☹️
Message 5 of 13
OK thanks, please let us know if the connection drops again
Message 6 of 13
Hi, Chris
The internet was off this morning until about 9am. I replaced the filter and rebooted the router and the internet service was restored. It's been stable since then but that proves nothing yet.
I don't know if there's noise on the line as I don't have a landline phone to test with.
Message 7 of 13
Hi daveonmako,
How has it been since your last post. Are you currently experiencing any problems with your telephone service, any noise on the line?
Message 8 of 13
Hi, Debbie
Firstly, thank you for sending out a new router so quickly.
I set up the new router straight away and until last night everything seemed stable. We had a very short loss of service for maybe 5 minutes, then this morning the internet went down for about 45 minutes. I ran a line check via my mobile phone and the service came back when the line check was completed. Strangely, the line test report came through as no issues having been discovered but this is not the first time that I ran a line check and service was restored at the end of the check so the report is clearly incorrect.
Could you please have a look at my service again and see if something can be sorted as the level of service being received from the broadband is not reflective of the price being paid each month.
Thank you
Message 9 of 13
Hi daveonmako
No problem 🙂
The router is on its way, please allow 24-48hrs for this to arrive
Message 10 of 13
Hello, Debbie
That would be excellent if you could do that.
Thank you
Message 11 of 13
Hi daveonmako
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Would you like me to send a replacement router for testing to see how the connection compares?
Skynet_TX
Message 12 of 13
Hi @daveonmako,
I'm assuming you have a model of router that just has the one single LED ?. If so, when you get the amber light is this a solid light, or a flashing light ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
