VPN Connection
kerryboyle2
Message 7 of 7
HI, I cannot connect to my company VPN. My work around at the moment is tethering to my phone, but that is inconvenient. This is quite urgent as it is making work difficult.
6 REPLIES 6
Message 1 of 7
Hi Kerry
I'm so glad to hear this 🙂
I have also sent you a Private Message with a link to a short survey for the Community.
kerryboyle2
Message 2 of 7
@Debbie-TalkTalk That's worked! Thank you very much!
Message 3 of 7
Hi Kerry
Thanks for your reply 🙂
I've made a change to your router firmware, please can you retest?
kerryboyle2
Message 4 of 7
@Debbie-TalkTalk As soon as possible would be great
Message 5 of 7
Hi kerryboyle2
Thank you for updating your Community Profile.
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 6 of 7
Hi kerryboyle2
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
