VPN Not Connecting
rhpsupport
Message 25 of 25
Hi, we are having issues with a PPTP VPN, everyone else at work can access apart from me.
Router Make and Model:
TalkTalk Wifi-Hub
Version: SG4K100135
24 REPLIES 24
Message 1 of 25
Hi rhpsupport
That's great news, thanks for letting us know 🙂
Message 2 of 25
Hi Chris,
Checked in with client and VPN is working, thank you for your help on this chris
Message 3 of 25
Just to checking in to see how you are getting on. Please let us know if you need any further assistance
Message 4 of 25
Message 5 of 25
Hi Chris,
Thanks for applying, just waiting to test within the next 1/2 hours.
Message 6 of 25
I can see the upgrade has now completed, is everything OK?
Message 7 of 25
OK, I'll start the upgrade now, please don't switch off your router
Message 8 of 25
Hi chris,
Yes please, now would be great
Message 9 of 25
Hi David,
Would you like me to update your firmware now, it can take up to 10 minutes to complete?
Message 10 of 25
Hi Chris,
Please find the line with the VPN issue on this account.
Message 11 of 25
Glad to hear it fixed the problem 🙂
Yes, if you ask them to post on the thread I'll update their firmware
Message 12 of 25
Hi Chris,
That has resolved the issue thank you!
We are also having another client also on talk talk with the same router and version with exactly the same issue, would it be possible if they comment on this thread to apply the same firmware update to their router?
Message 13 of 25
Hi Justine,
How are you getting on, did the firmware update resolve the VPN issue?
Message 14 of 25
Message 15 of 25
Yes that's ok to go ahead with
Message 16 of 25
We can try a firmware upgrade, this usually resolves VPN issues. Would you like to give it a try?
Message 17 of 25
Hi Chris,
Details of the line can be found in this profile. If you need any more information, please let me know.
Message 18 of 25
Yes, if they could register on the Community and post on this thread then we'll be able to help
Message 19 of 25
hi chris this is an issue regarding a client, would it be best for them to contact you directly?
Message 20 of 25
Thanks, is one of the telephone numbers the line with the issue (I can't find any details on either)?
