Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
VPN Stopped working - help required please ๐Ÿ™๐Ÿป
Maudymumfuzz
Message 10 of 10
Hi there,
I know there are many posts like this one but I am currently commuting between hospital and working from home, when suddenly my VPN stopped working when I tried to sign in from home. I havenโ€™t previously experienced any issues but realised itโ€™s a problem when I ventured on here. Can anyone advise how this can be sorted please?
thanks so much
9 REPLIES 9
Message 1 of 10
Hi Maudymumfuzz
How are getting on?
Debbie ๐Ÿ™‚
Message 2 of 10
Hi Maudymumfuzz
Thank you ๐Ÿ™‚  Please let us know how you get on.
Message 3 of 10
Thanks so much Debbie and everyone for the replies, I hope you all enjoyed the holiday weekend ๐Ÿ™๐Ÿป. I am heading home tomorrow so I will retest and hopefully have good news! I really appreciate your help xx
Message 4 of 10
Hi Maudymumfuzz
I've made a change to your router firmware, please can you retest and let us know how the connection compares?
Skynet_TX
Message 5 of 10
The support team won't have been around over the holiday weekend, so hopefully you will hear more tomorrow.
Message 6 of 10
Hi Debbie,
Could you advise when the firmware will be updated please?
thanks so much
Maudy
Maudymumfuzz
Message 7 of 10
thanks so much for the replies, I am home atm if that helps. The router is a SG4K100130 but I would have to check with IT regarding the VPN and they arenโ€™t in until Tuesday. I was hoping the firmware update would sort things ๐Ÿ™๐Ÿป..
thanks so much I really appreciate it
Maudy
Message 8 of 10
Hi Maudymumfuzz
Apologies for this.
I will need to make a change to your router firmware.
When would be the best time to update the firmware? We advise to leave the router switched on without rebooting whilst we update the FW.
Skynet_TX
Message 9 of 10
Hi @Maudymumfuzz,
What model of router do you have ?
If you have the Sagemcom Wi-Fi Hub can you go to http://192.168.1.1/ and see what 'version' it says near the bottom of the login screen (it will start with SG4K)
Also, what VPN software are you trying to use, or is it the built in Windows 10/11 VPN ?
