VPN help
Charlotte5775
Message 30 of 30
Hello, this is a final attempt at finding help from talk talk regards my VPN issues. My VPN has always worked fine - around 3 weeks ago it suddenly stopped. I have internet connection and my VPN works elsewhere just not at home. After many lengthy conversations, Talk Talk reluctantly sent me a new router which has made no difference. I have lost 3 weeks worth of hours as I work from home and am now in desperate need of assistance. Our IT department at work have exhausted all options and as my VPN connects everywhere BUT at my home, it has to be an issue with Talk Talk. PLEASE HELP!
29 REPLIES 29
Message 1 of 30
That's great news Charlotte, thanks for letting me know 🙂
Charlotte5775
Message 2 of 30
Chris- thank you so much!!! It seems to be working!
Message 3 of 30
OK I'll start the update now, please don't switch off the router
Charlotte5775
Message 4 of 30
Absolutely yes please. I’m so sorry for the mix up! I have to pop out now so may go quiet but I’ll test again when I’m back
Message 5 of 30
Yes, that explains it 🙂
OK I can change the firmware version on your current router which hopefully will resolve the problem - would you like me to do this now, it can take up to 20 minutes to complete?
Charlotte5775
Message 6 of 30
So sorry I think I may have given the wrong one earlier - not helpful
Charlotte5775
Message 7 of 30
Yes- it’s [removed]
Message 8 of 30
Thanks, Could you just confirm that the telephone number in your community profile is the telephone number of the telephone line with the issue
Charlotte5775
Message 9 of 30
That’s the S/N number
Charlotte5775
Message 10 of 30
N7202024N015922
Message 11 of 30
That's strange, the one you are using now should have black holes. Could you take a look at the label on the back of the router and let me know what the model number is
Charlotte5775
Message 12 of 30
They both have bronze holes
Message 13 of 30
If you look at the holes in the front of the router are they both just black or is one of them a bronze colour?
Charlotte5775
Message 14 of 30
Rebooted and tested and the same message is appearing. Yes, I still have the new router. They’re both exactly the same model though (not sure if that is important)
Message 15 of 30
OK thanks, could you just reboot the device that you're running the VPN on and retest.
Do you still have the other router?
Charlotte5775
Message 16 of 30
Hi Chris. I did only do 30 seconds last week yes. I have just turned it back on. It’s been off for for a little more than 30 minutes and the same message is coming up.
Message 17 of 30
No problem, out of interest, did you only switch it off for 30 seconds when you were asked to do this last week?
Charlotte5775
Message 18 of 30
So sorry- I did 30 seconds. Bear with me
Message 19 of 30
Thanks Charlotte but you need to switch it off for at least 30 minutes
Charlotte5775
Message 20 of 30
No, the same message is coming up
