VPN not connecting
Craig1962
Message 4 of 4
My connection has also stopped working, how do you get talktalk to adjust the firmware which has been highlighted as a problem?
3 REPLIES 3
Message 1 of 4
How are you getting on? Do you still need assistance with this?
Message 2 of 4
Hi Craig
Is your router switched on at the moment? I will need to make a change to your router firmware.
Skynet_TX
Message 3 of 4
Hi @Craig1962,
If you have the Sagemcom Wi-Fi Hub then this will probably have been caused by the firmware upgrading to a new version.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
The support team here will be back tomorrow, although they will have to catch up on the posts that have been made over the last four days first. So just wait for one of the support team to reach this post, they will then be able to help.
