VPN not working
jamesluckett
Message 4 of 4
I need help, I am trying to connect to my work VPN. I have had three calls with Technical support and they have not resolved the issue. If I use my mobile hotspot it works but if I use the Talk Talk router it will not let me connect to my work VPN. I have tried splitting the SSID and setting them as two different names i.e. Talk24  and Talk 5. This has not worked. I have tried connecting my VPN to two friends' Internet with Sky and BT and I can connect to VPN with no problems. I don't know what else I can do to try and resolve this except cancelling by Talk Talk Internet and going with another provider. Can anyone suggest anything?
JSL
3 REPLIES 3
Message 1 of 4
Just checking back in to see if everything is now ok?
Message 2 of 4
Hi James
I've made a change to your router firmware, please can you retest?
Message 3 of 4
Which make/model of router are you using & what firmware is it running?
