Why does my broadband keep failing?
on 02-06-2024 07:27 PM
Message 26 of 26
I am having ongoing problems with receiving a continuous and stable internet connection. I feel fairly certain that the problem is with the 2.4ghz channel, as items connected to this channel keep failing
- Sometimes everything appears ok, and then I have no internet on wifi
- As I look on my laptop at the “Network and Sharing Centre” I can see the connection coming and going as the wifi attaches and the detaches itself.
- I cannot always persuade a cable connection to work, either.
- Although a speed check shows an acceptable download of up to 19mbps, sometimes the actual speed is too slow for most websites to load, including your dashboard
- Current speeds between 1 and 3mbps
- I cannot stream a complete programme on TV either through cable or wifi
- I get messages about unstable internet connection
- Zoom gets cut off in mid-conference
- Your dashboard takes a minute or so to load
- When I try to find information on the dashboard, I get thrown out and have to log in again.
- The dashboard typically looks like this, although the internet is connected.
- The dashboard does not recognize all devices (including my laptop) when they are connected.
CAN YOU PLEASE FIX THIS IMMEDIATELY? IF YOU CAN’T PLEASE HELP ME TO CANCEL THE CONTRACT
Labels:
- Labels:
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
25 REPLIES 25
on 03-06-2024 01:39 PM
Message 21 of 26
I rather think your response is limited in its scope. Despite what you say, my internet is NOT working. Although I'm typing this I am having to wait to pounce when the internet is working to be able to send it. I just tried to refresh this page and it refused. I know Chris has kindly offered to help, but I think a less dismissive response from you would be appreciated. I would like you (Talktalk) to take responsibility for what's happening (or not).
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-06-2024 01:28 PM
Message 22 of 26
s this also affects wired (Ethernet connections), then as you say the problem is not purely WiFi. When you get the problem, what happens to the white light on the front of the router? Have you tried moving the router temporarily to the test socket, which is behind the master socket's removable faceplate (if you have that design)? Please can you try it with a new microfilter?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-06-2024 12:25 PM
Message 23 of 26
Hi mackerel,
I can see that Keith has kindly offered to help you with this. I've checked your connection and your router is in sync at 23Mbps with a low error count.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-06-2024 11:16 AM
Message 24 of 26
Many thanks for your comments. Specific points:
- it's not just wifi, but cable connection that suffer the same issues.
- I couldn't reply any sooner, as the internet was not available. I've just re-booted the router and I am on-line - for now.
- This isn't the type of internet I signed up for. I expect to be able to use it without messing about all the time. What happens to customers suffering in the same way who are just unable to understand any of this?
- Following the re-boot, I'm on 5ghz and it's working
- I will have one go at optimisation, so please send me instructions. Thanks for the offer.
- I have renamed devices any number of times, and after each outage I usually have to do it again.
Once again, many thanks for offering to help. It's a shame that you are Talktalk's first resort - I would hope that they would step up as soon as anyone has a problem
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-06-2024 10:02 PM
Message 25 of 26
Where your router is not recognising some of your devices this is easy for you to sort out. Click on the Manage My Devices button & from there select Manage Advanced settings. You will see a list of the devices currently connected. Click on any of them & from there you can rename them to what you want, plus set a suitable icon.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
