on 29-06-2023 03:26 PM
My router is showing a download speed of 16.5 being received but I am only able to get 7.6 on wireless ipad and laptop and 6.2 on a test wired laptop.
Spent 90 minutes on chat to support who kept telling me I was receiving the expected download. Finished no further on than i was using the automated troubleshooter the day before.
On Friday speeds were OK (16.5) on Saturday dropped to 10; Sunday onwards 8.
I have checked for local congestion on the wifi channels using Metageek Inssider and changed to lowest used but no difference. Any suggestions.
Gordon
on 03-07-2023 01:58 PM
Hi Gordon1946
Apologies, we can send you a router for testing, would you like us to arrange this?
on 03-07-2023 01:55 PM
No I did ask about a router for testing, but was told by Mycha he didn’t have availability of one to send.
it was my thought that router may be faulty as original problem of speed to equipment occurred on both Wi-Fi and wired ports even though router menu showed receiving download of 16.5, but your speed check results only showed 8.
I have tested all my internal wiring which appears ok.
Just note to let you know I do appreciate problems of resolving issues as I was IT Support manager for my organisation in Lancashire for 14 years befor retiring in 2011.
on 03-07-2023 01:44 PM
Hi Gordon1946
Thanks for confirming. Have we also sent you a new router for testing?
Next step following this will be an Openreach engineer visit.
on 03-07-2023 01:39 PM
Yes. It has been since I had contact with Mycha in Tech support online earlier in the week. Heard nothing further from him so contacted the community for help.
on 03-07-2023 01:33 PM
Hi Gordon1946
I've checked the connection stats and the connection appears to be more stable but the sync speed hasn't increased.
Is the router currently connected at the test socket?
on 03-07-2023 01:26 PM
Hi Chris,
Connection has remained stable over weekend at the reduced download speed of 15 mbs at the router with no changes made over weekend.
This is giving me a speed of 13.6 on my equipment.
on 30-06-2023 11:36 AM
OK thanks. If the connection remains stable DLM should you move you back to the faster profile. Could you bump the thread on Monday and we'll check to see if anything has changed
on 30-06-2023 11:27 AM
No. We haven't noticed any.
on 30-06-2023 10:39 AM
It looks as though the line management system (DLM) has moved you to slightly slower profile due to disconnections. Are you experiencing any problems with your telephone service, any noise on the line?
on 30-06-2023 10:31 AM
Sorry for the delay in responding @Gordon1946, obviously this won't be WiFi interference at all then.
on 30-06-2023 10:17 AM
Hi Chris. Carried out as requested.
Router connection now 15mbs, down from the 16.5 I was previously receiving.
speed test on laptop and iPad now 13.8 where previously was at 16 until last Saturday when everything dropped.
on 30-06-2023 08:56 AM
Hi Gordon,
Could you switch the router off and leave it off for at least 30 minutes then switch back on and retest, please let us know if there's any improvement following the restart
on 29-06-2023 08:18 PM
Thanks for your contact.
Router is Sagecom Fast 5364
Firmware SG4K100136
My broadband is FTTC
My problem does not only exist on wifi but also on wired connections.
Gordon
on 29-06-2023 03:29 PM
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
