on 07-07-2023 03:30 PM
Hi, my VPN is not working. I have tried several options from the internet and found this post that Debbie from Talk Talk support fixed for the user Lisa. Can you please assist me as I did phone, TT support said they cannot help me. I only moved yesterday to TT and want to cancel my broadband if I cannot resolve this as I must work from home and need to use the VPN. I would rather stay but at the moment it is for me critical to have a working VPN to be able to work.
Can't connect to work VPN - TalkTalk Help & Support
Solved: VPN connection not working - TalkTalk Help & Support
on 11-07-2023 09:53 AM
Hi EugeJEuli
Do you still need help with this?
on 10-07-2023 06:54 AM
Hi EugeJEuli
Apologies for the delay.
Your router has the latest firmware version and this should work with VPN.
Are you still experiencing the issue when connecting to VPN?
on 07-07-2023 09:54 PM
Which make/model of router do you have & what firmware is it?
Which VPN client are you using?
