VPN connection not working
dlotnu
Message 23 of 23
My VPN connection to work has stopped working and I am getting an error message which says "Error 619 : A connection to the remote computer could not be established, so the port used for this connection was closed."
It was working OK on Tuesday 11 January, but not when I tried it on 16 and 17 January and it has not worked since. I have noted that a number of users appear to having a similar problem from Thursday 13 January.
The router which we have  (with no problem for about 2 years) is a Sagemcom Fast 5364.
Please can you let me know if there is a solution to this issue as I need to be able to work from home which I am unable to do at present.
Many thanks,
Alistair
22 REPLIES 22
Message 1 of 23
Hi @Graham57
I will take a look at your topic now.
Skynet_TX
Message 2 of 23
Hi @Graham57,
The support team will get back to you on the new topic that you have created about this issue.
Graham57
Message 3 of 23
Hi I have the same issue, worked from home during lockdown then went back to the office now I t doesn’t work, please help.
Graham
Skynet_TX
Message 4 of 23
@Rosie23 Staff here will respond to you on the new topic that you have created
Rosie23
Message 5 of 23
IM HAVING SAME PROBLEM PLEASE HELP
Message 6 of 23
Hi @FSantos
I will post on your topic on the Community.
Message 7 of 23
@FSantos, staff will only reply to the original poster, so please look out for a response on your own thread, after the weekend.
FSantos
Message 8 of 23
Hi, same issue here.
My VPN connection to work has stopped working from 13thh January and I am get the error message  "Error 619 : A connection to the remote computer could not be established, so the port used for this connection was closed."
It was working OK from March 2020, . I have noted that a number of users appear to having a similar problem from Thursday 13 January.
The router which we have  (with no problem for about 2 years) is a TalkTalk WI-FI HUB FAST 5364-3. T8
Many thanks,
Fabio
Message 9 of 23
Hi Alistair
No problem 🙂
If you do experience any further issues then please let us know.
Message 10 of 23
Thanks Skynet_TX
There is a returns bag and prepaid returns label in the box so I will use those to return the old router.
Kind regards
Alistair
Message 11 of 23
Thanks Debbie, I will do that.
Thanks again to both you and Skynet_TX for all your help with this.
Kind regards
Alistair
Message 12 of 23
Hi Alistair
I'm so glad to hear this 🙂
Please can you return your old router using the pre paid returns bag.
Skynet_TX
Message 13 of 23
If there was a returns bag and prepaid returns label provided with you new router then you can return the old router in that. If no returns bag was supplied, the staff here will be able to send you one.
Message 14 of 23
Hi Debbie
I received the new router and it works fine with my VPN connection now.
Do you want me to send the other one back to you ?
Thank you you very much indeed for your very quick response and solution to my problem, it is much appreciated.
Kind regards
Alistair
Message 15 of 23
Message 16 of 23
Many thanks Debbie
I will let you know how I get on with the new router.
Thanks again for your help and quick response to this issue.
Alistair
Message 17 of 23
Hi dlotnu
The router is on its way, please allow 24-48hrs for this to arrive
Message 18 of 23
Hi Debbie
Thank you for your reply.
Yes, please can you arrange that.
Do you know when you will be able to send it please ?
Alistair
Message 19 of 23
Hi dlotnu
I will need to send a Huawei WIFI hub, are you happy for me to arrange this?
dlotnu
Message 20 of 23
Hi Skynet
Yes, it does say SGK100130, so hopefully the Talk Talk staff will be able to respond tomorrow.
Thank you for your help, much appreciated.
