on 19-11-2022 05:45 PM
Hi, I am having problems with the 2.4 Wi-Fi constantly dropping off, the 5g Wi-Fi is rock solid.
I have some Wi-Fi plugs and sensors that are 2.4 only, so this is causing connection problems.
I have tried different channels and different wireless protocols with no luck. are there any router settings that will make the 2.4 Wi-Fi stable. The router is a DG8041W TalkTalk Wi-Fi Hub
Version v1.05t .
Thanks for any help.
on 21-11-2022 11:28 AM
Hello
Thanks for the reply, Please find attached some screen shots. I had trouble attaching the pictures so had to zip them.
My ssid is TALKTALKBEEC69
Hope this is what you required.
on 20-11-2022 01:21 PM
The guide is mainly on how to use different analysers & take screenshots from them. However, there is no point in reinventing the wheel. Please can you send me screenshots of the various views? The views I need to see are (terminology may vary from analyser to analyser):-
AP view, please make sure that all of your SSIDs are visible in this window.
Signal Strength/Time graph– please ensure that the network in question is highlighted in the AP view first. Let this run for 5 mins before taking the screenshot.
I will need to know which network name(s) (SSID) is/are your one(s).
To include the screenshots for me, please insert them all via the “Photos” icon on the editor's toolbar of your reply, in a mobile browser it is the “Picture” icon. Please ensure that the Size parameter in this facility is set to Large.
Alternatively, you can PM me, if you do, please can you also provide a link in there to your thread, to help me find it more easily. When I see your screenshots, I made need some others depending on what the first set of them show.
on 20-11-2022 11:16 AM
Thanks for the reply, I have done a scan with a Wi-Fi analyser on my phone and next door are using 5g. I would be interested in your guide to see if things can be improved.
Thanks again.
on 20-11-2022 11:09 AM
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
