on 21-01-2024 10:53 PM
Hi Can you please turn wifii optimisation off on my account, please?
on 26-01-2024 09:33 PM
@langy71, please post on your own thread.
Staff will reply after the weekend.
on 26-01-2024 09:10 PM
I have now had to swap back to the stock router from talktalk.the new one kept disconnecting.on the talktalk website it says there is a problem with my broadband.
Can you check it please.
on 25-01-2024 06:27 AM
Hi Mbeven
I'm so glad to hear this, thanks for letting us know.
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 24-01-2024 06:10 PM
Much better now. I’m able to set the channel I want without it changing by itself. Thanks.
Not sure why it’s so tricky to do this though. When you change the channel in the wifi settings it should stick. Anyway..!
on 23-01-2024 06:49 AM
Hi Mbeven
How's the connection been since the WIFI optimisation was switched off?
on 22-01-2024 08:07 AM
Hi Mbeven
Thank you 🙂
The WIFI optimisation has now been switched off.
Please let us know how the connection compares.
on 22-01-2024 07:29 AM
Hi Debbie, thanks. This is updated
on 22-01-2024 07:17 AM
Hi Mbeven
Please can you add your name and TalkTalk landline number to your Community Profile, I can then switch the WIFI optimisation off for you.
